Even snel uit mijn pcb programma gehaald.
De DC DC converter heeft geen type nummer maar ik heb er een ebay link bij gedaan.
Partlist
Exported from yaesu-450-with-led-rose-print veron v2.1.brd at 23-08-18 08:51
EAGLE Version 5.10.0 Copyright (c) 1988-2010 CadSoft
Part Value Package Library Position (mm) Orientation
C1 33p C025-030X050 rcl (108.2675 52.07) R0
C2 33p C025-030X050 rcl (108.2675 55.5625) R0
C3 100n C025-030X050 rcl (101.6 32.7025) R0
C4 100n C025-030X050 rcl (107.95 47.625) R90
C5 100n C025-030X050 rcl (61.2775 33.9725) R270
C6 100n C025-030X050 rcl (108.585 4.445) R0
C7 100n C025-030X050 rcl (123.19 49.2125) R270
C8 100n C025-030X050 rcl (142.24 36.83) R90
C9 100n C025-030X050 rcl (104.775 81.915) R180
C10 100n C025-030X050 rcl (82.2325 81.915) R180
C12 100uF E2,5-7 rcl (83.82 37.465) R90
IC1 Atmega328p DIL28-3 atmel (106.68 39.6875) R180
IC2 PCF8574P DIL16 micro-philips (135.255 44.45) R90
IC3 PCF8574P DIL16 micro-philips (100.965 11.43) R180
IC4 PCF8574P DIL16 micro-philips (112.395 74.93) R0
IC5 PCF8574P DIL16 micro-philips (68.2625 41.5925) R90
IC6 PCF8574P DIL16 micro-philips (89.8525 74.93) R0
JP1 header 1X02 SparkFun (115.57 48.895) R90
JP2 header 1X03 SparkFun (123.19 29.5275) R180
JP4 header 1X05 SparkFun (93.98 29.5275) R180
JP5 header 1X03 SparkFun (113.03 29.5275) R180
JP6 header 1X03 SparkFun (98.425 29.5275) R0
L1 22uH IR-2 rcl (78.105 37.465) R270
LED1 LED5MM SparkFun (100.965 -3.175) MR0
LED2 LED5MM SparkFun (108.585 -2.54) MR0
LED3 LED5MM SparkFun (115.8875 -0.9525) MR0
LED4 LED5MM SparkFun (122.555 1.905) MR0
LED5 LED5MM SparkFun (129.2225 5.715) MR0
LED6 LED5MM SparkFun (134.62 10.795) MR0
LED7 LED5MM SparkFun (139.3825 16.51) MR0
LED8 LED5MM SparkFun (143.51 22.86) MR0
LED9 LED5MM SparkFun (146.3675 29.845) MR0
LED10 LED5MM SparkFun (147.955 36.83) MR90
LED11 LED5MM SparkFun (148.59 44.45) MR90
LED12 LED5MM SparkFun (147.955 52.07) MR270
LED13 LED5MM SparkFun (146.3675 59.055) MR0
LED14 LED5MM SparkFun (143.51 66.04) MR0
LED15 LED5MM SparkFun (139.3825 72.39) MR0
LED16 LED5MM SparkFun (134.62 78.105) MR0
LED17 LED5MM SparkFun (129.2225 83.185) MR0
LED18 LED5MM SparkFun (122.555 86.995) MR0
LED19 LED5MM SparkFun (115.8875 89.8525) MR0
LED20 LED5MM SparkFun (108.585 91.44) MR0
LED21 LED5MM SparkFun (100.965 92.075) MR180
LED22 LED5MM SparkFun (93.345 91.44) MR180
LED23 LED5MM SparkFun (86.36 89.8525) MR180
LED24 LED5MM SparkFun (79.6925 86.995) MR180
LED25 LED5MM SparkFun (73.3425 83.185) MR180
LED26 LED5MM SparkFun (67.6275 78.105) MR180
LED27 LED5MM SparkFun (62.5475 72.39) MR180
LED28 LED5MM SparkFun (58.42 66.04) MR180
LED29 LED5MM SparkFun (55.5625 59.055) MR180
LED30 LED5MM SparkFun (53.975 52.07) MR270
LED31 LED5MM SparkFun (53.34 44.45) MR90
LED32 LED5MM SparkFun (53.975 36.83) MR90
LED33 LED5MM SparkFun (55.5625 29.845) MR180
LED34 LED5MM SparkFun (58.42 22.86) MR180
LED35 LED5MM SparkFun (62.5475 16.1925) MR180
LED36 LED5MM SparkFun (67.6275 10.795) MR180
LED37 LED5MM SparkFun (73.3425 5.715) MR180
LED38 LED5MM SparkFun (79.6925 1.905) MR180
LED39 LED5MM SparkFun (86.36 -0.9525) MR180
LED40 LED5MM SparkFun (93.345 -2.54) MR180
LED41 LED5MM SparkFun (111.76 66.04) MR180
LED42 LED5MM SparkFun (90.17 66.04) MR180
Q2 BC547 TO92 transistor-npn (88.9 59.69) R180
Q3 16MHz QS special (102.87 51.435) R270
R1 1K2 0204/7 rcl (107.315 26.035) R180
R2 27K 0204/7 rcl (94.615 26.035) R0
R3 120K 0204/7 rcl (83.82 26.035) R0
R4 10K 0204/7 rcl (126.365 47.3075) R270
R5 1K 0204/7 rcl (68.2625 56.515) R0
R6 1K 0204/7 rcl (86.36 51.435) R90
R7 15K 0204/7 rcl (118.11 26.035) R180
R8 1K 0204/7 rcl (68.2625 59.69) R0
R9 5K CA6V pot (130.81 66.3575) R180
R13 100 0204/7 rcl (83.185 51.435) R270
R22 100 0204/7 rcl (80.01 51.435) R270
R49 220 0204/7 rcl (68.2625 53.34) R0
R50 220 0204/7 rcl (123.825 74.93) R270
R51 220 0204/7 rcl (134.9375 26.67) R180
R52 220 0204/7 rcl (85.09 10.795) R90
S1 set TACTILE-PTH SparkFun (116.205 20.955) MR0
S2 left TACTILE-PTH SparkFun (106.045 20.955) MR0
S3 right TACTILE-PTH SparkFun (95.885 20.955) MR0
S4 mem TACTILE-PTH SparkFun (85.4075 20.955) MR0
SV1 header MA06-1 con-lstb (126.6825 59.69) MR0
SV2 header MA06-1 con-lstb (101.2825 59.69) MR0
SV3 header MA06-1 con-lstb (121.92 54.61) R180
Partlist
Exported from relaisboard-v2-1.brd at 23-08-18 08:53
AC1 header 1X01 SparkFun (32.7026 -44.7676) R0
AC1-1 header 1X01 SparkFun (38.1 -44.7675) R0
AC2 header 1X01 SparkFun (27.6226 -44.7675) R0
AC3 header 1X01 SparkFun (43.18 -44.7675) R0
B header 1X01 SparkFun (1.27 -28.575) R0
B1 gelijkrichter RB1A rectifier (40.64 -37.7825) R0
C header 1X01 SparkFun (1.27 -33.655) R0
C3 100uF E3,5-10 rcl (30.7975 -37.9413) R270
JP1 header 1X05 SparkFun (1.27 -3.175) R270
L L 1X01 SparkFun (1.27 -23.495) R0
R R 1X01 SparkFun (1.27 -18.415) R0
U$1 G3MB_0609 G3MB_0609 pe1br (33.3375 -6.6675) R270
U$2 G3MB_0609 G3MB_0609 pe1br (46.6725 -6.6675) R270
U$3 G3MB_0609 G3MB_0609 pe1br (40.005 -6.6675) R270
U$4
https://www.ebay.com/itm/1PCS-DC-DC-LM2 ... SwvzRXzOBg DCDC pe1br (16.8275 -20.955) R90
